Re: IH 674 ? 2 reservoirs
Posted by jimb2 on November 08, 2014 at 05:54:16 from (99.241.118.87):
In Reply to: IH 674 ? 2 reservoirs posted by John Zitkus on November 07, 2014 at 07:47:51:
Hi John,
There is no syncro on Lo/Hi but 1 to 4 should
be syncro. We had a 674 without T/A and Dad
upgraded to 684 with T/A.
Does your 674 have a T/A?
Take off the inspection plate under the clutch
housing and inspect the pressure plate and PTO
shaft splines. Since you have the hydraulic
pump out, reach in and see if you can turn the
PTO shaft which drives the hydraulic pump. You
should not be able to turn the PTO shaft at the
hydraulic pump drive gear.
It is unusual that the hydraulic pump would
quite all of a sudden unless the drive gear key
shears or the PTO drive splines strip. Usually
hydraulic pumps gradually become weaker over
time and you have to rev engine to max to lift
anything with the loader. Other possibilities
are blown O-rings or other problems in MCV.
JimB
  Upload Photo  Select Gallery Photo  Attach Serial No List
