Re: Setting Relief valve
Posted by redforlife on November 10, 2014 at 21:48:59 from (68.234.121.124):
In Reply to: Setting Relief valve posted by kopeck on November 10, 2014 at 16:33:50:
Adjust it down so you know for sure it is less than 1200. Then hook tractor up to a hydraulic equiped peice of equipment. If you don't have enough pressure, you know you are to low. Then simply adjust it up just enough to make your hydraulics do what you want. If you switch out equipment, it may need adjusted up a bit more if that particular thing needs more pressure, but atleast you know you are throwing to low of pressure for what you are doing instead of to much. You could eliminate the need for a guage this way, unless you are using something that is going to excede the 1200, which you shouldn't be using anyways.
  Upload Photo  Select Gallery Photo  Attach Serial No List
