Setting Relief valve
Posted by kopeck on November 10, 2014 at 16:33:50 from (66.243.203.185):
So I'm installing a new spool valve on my SM. The relief valve is set from the factory @ 1500 PSI. The live pump maxes out at 1200 PSI.
This is the only valve in the system, the relief suppose to go down to 1000 PSI but there no stop to say it's reached it's lowest value.
So my question is, since I don't have a gauge, just install it, and keep backing it off until the valve doesn't stall the engine at low idle or is there a better way?
K
