Re: Setting Relief valve
Posted by Dennis K (WA) on November 11, 2014 at 09:35:41 from (24.21.78.195):
In Reply to: Setting Relief valve posted by kopeck on November 10, 2014 at 16:33:50:
I guess I miss understood the original post. I took it that it had a relief at 1200psi which would make my statement true.
But, if it does not and the pump can only stand 1200psi then, yes, you need a gauge to adjust the relief in your add on valve.
Sorry
Dennis
