Re: Setting Relief valve
Posted by mkirsch on November 11, 2014 at 12:53:12 from (72.45.143.81):
In Reply to: Setting Relief valve posted by kopeck on November 10, 2014 at 16:33:50:
If he's using the bottom drain on the belly pump reservoir for suction, and running the return line into the fill port, there is NO relief valve in the system.
The spool valve will be the sole source of relief.
pete 23's right, that pump can do 1500PSI no problem. So, anything less than the factory setting is perfectly fine on the relief.
