Re: Magneto or Distributor?
Posted by Janicholson on November 15, 2014 at 12:30:49 from (74.60.94.18):
In Reply to: Re: Magneto or Distributor? posted by Tom Fleming on November 15, 2014 at 12:09:29:
The centrifugal advance built into the distributor drive shaft (under the plate that the points mount on) allows timing to be closer to TDC at idle, and farther from TDC at full rated RPM. This is important for smooth idle and good combustion through all operating speeds. Fuel in the combustion chamber burns with a predictable flame front (leak a trail of gasoline for 50 feet and then put a match to one end. The time it takes to ignite the fuel at the other end is the flame travel rate in air, no compression. The same happens in the combustion chamber, only we can't see it. The change in timing accounts for this variation, which in turn allows maximum cylinder combustion pressure to occur ~ 8 to 10 degrees after TDC. Smooth. Jim
  Upload Photo  Select Gallery Photo  Attach Serial No List
