Re: Magneto or Distributor?
Posted by Tom Fleming on November 15, 2014 at 12:09:29 from (67.20.239.72):
In Reply to: Magneto or Distributor? posted by dmat58 on November 14, 2014 at 21:37:45:
Pete, I agree with you that a battery ignition is much more adaptable if you are going to modify an engine, such as to make it a puller, up the compression, etc. etc. etc.
However, for a stock engine, not sure why you say it gives a smoother running engine at lower RPM's? I agree, that the faster you turn a mag, the "hotter" the spark, but at stock RPM's the H4 mag produces a fat spark. I have a BN and an A both with stock C113's that idle VERY nicely.
Also, when the weather is cold, a mag will produce a much hotter spark than a battery ignition due to the voltage drain of cranking a cold engine. that of course produces a more consistent cold starting engine.
so, I am not challenging you, but actually would like to understand your low RPM statement.
