Re: 450 lp will start up but will not keep running
Posted by Centex Farmall on November 18, 2014 at 21:06:59 from (72.105.162.89):
In Reply to: Re: 450 lp will start up but will not keep running posted by rustyrelic on November 17, 2014 at 16:53:59:
That little pin is what goes between the diaghram and the low pressure side lever. This is your problem.
The pin clips between the two small metal plates in the middle of the diaghram. It should have a head like a tiny nail and then after about 1/4" or so it should get little bigger in diameter. There should be a thin steel plate that helps guide it.
Is there damage or corrosion to the pin or plates on the diaghram?
  Upload Photo  Select Gallery Photo  Attach Serial No List
