Re: TD35 and McCormick 70 plow
Posted by rustred on November 22, 2014 at 07:53:59 from (74.214.152.80):
In Reply to: TD35 and McCormick 70 plow posted by mschwartz on November 22, 2014 at 06:59:39:
very nice unit. I see no crank, do you just put the crank In to start it? or pull it?
the coulters are more for sod . they can be lowered as they wear and I believe they can accept a couple inches of wear from new. they also got taken off for plowing stubble and less chance of plugging.
  Upload Photo  Select Gallery Photo  Attach Serial No List
