Re: TD35 and McCormick 70 plow
Posted by mschwartz on November 22, 2014 at 08:09:19 from (216.163.99.206):
In Reply to: Re: TD35 and McCormick 70 plow posted by rustred on November 22, 2014 at 07:53:59:
Yes I carry the crank under the seat on this one, the cast bearing that holds the crank was broken and i have not gotten around to swapping it out. Tractor also has a starter but I rarely use it, handy when it is really cold out or I have flooded it. Will usually start within three or four cranks. This is the only plow that I have put all of the coulters on most around here just plowed with the rear one to keep a clean furrow. I thought they might help with the alfalfa sod. Plowed pretty hard, lugged pretty hard in spots using second but was actually spinning tracks in those spots when I went to low gear.
  Upload Photo  Select Gallery Photo  Attach Serial No List
