Posted by Lucas0522 on November 22, 2014 at 16:11:17 from (107.77.75.88):
In Reply to: Super H carburetor posted by Lucas0522 on November 22, 2014 at 13:20:46:
I've narrowed it down to the float,?I believe, because it floods even with the old needle, and this all started happening after I bent the float to the specs that came with the rebuild kit.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
