Posted by GordoSD on November 22, 2014 at 17:33:03 from (66.128.161.171):
In Reply to: Re: Super H carburetor posted by Lucas0522 on November 22, 2014 at 16:11:17:
The fact that you told us a rebuilder "put new bushings" in it causes me some concern as to your understanding of a carb. No way any bushing controls fuel flow is there.? That said. please explain in detail how you "set the float level" Float hanging down, or carb inverted and float in bowl. Measurement from where to where? Did you use a tape measure or a engineer scale or steel gauge? I think you are way off on the float setting.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
