Re: I think my Farmall Super M tranny is Frozen (Ice)
Posted by Dean Olson on November 27, 2014 at 18:17:25 from (166.137.12.131):
In Reply to: I think my Farmall Super M tranny is Frozen (Ice) posted by chappie on November 27, 2014 at 17:51:39:
I/we used to use an old 55 gallon drum cut down enough to slide under a diesel engine. Put a bag of charcoal in and light it up. We did this to get a tractor started.
No reason you couldn't thaw out a trans this way.
Trans and diff share the same oil. Once you get it thawed out and drained I use 5 gallons of diesel and run the tractor slow and easy enough the get everything rinsed. Drain the diesel then add your oil. No reason to waste oil that way.
If it's a belly hydraulic pump it's possible its froze up also and killing the engine. But due to the fact it's a different fluid and separate from the trans, I doubt that's the issue.
  Upload Photo  Select Gallery Photo  Attach Serial No List
