I had the same problem with my Super M a couple winters ago. After sitting several weeks with temps in the single digits I discovered the rear end had locked up solid. When I was able to drain it the following spring I got several gallons of crystal clear water before the old oil began to appear.
I flushed the rear end with 5 gallons of diesel, let it drain overnight then refilled with fresh 85W-90. Haven't had a problem with it since.
To thaw out yours, recommend to use a torpedo heater or charcoal burner as other suggest. It'll take several hours of heating - there's a LOT of iron, water and oil that's gotta be thawed out!
Regarding a source new gear oil, SHOP AROUND! Last I checked Autozone and TSC both offered 85W-90 in 5 gallon buckets for about $59.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
