Had this problem b on a MM U and a wd45 allis I have. Its a hazard of obtaining your machinery in fence rows. Tried torpedo heaters that I use to unthaw semi's on th he side of the road. 175,000 btu diesel burners. No luck. I stuck a magnetic block heater on the bottom of the rear end over night problem solved. In your case I would say transmission because mine were fine with the transmission in neutral. I took them in and flushed them with diesel after they were good and warm. If it kills it as soon as you let off th he clutch with the transmission in neutral the counteract is probably frozen or all this was a waste because its stuck in two gears at once. Been there too.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
