The first thing that I would do is get a drain pan and set it under the drain plug and slowly take it out and if you have ice in put the plug back in and get some heat on it to thaw the ice. Once the water stops coming and oil comes quick put the plug back in and you should be good to go. If you haven't been using 4th and 5th gear I would say that you have some rusty rails, and depending how rusty they are you may or may not have to pull the top cover off to loosen them up. If it is working ok after you get the water out I would not worry about it till spring.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
