Re: International 300 utility
Posted by Janicholson on November 29, 2014 at 10:14:57 from (74.60.94.18):
In Reply to: International 300 utility posted by mrc958 on November 29, 2014 at 09:04:07:
The push button is a low current device, less than 4 amps. It is used to energize the starter relay. (That little film can sized device on the side of the starter) if it is smoking at that push
button, there are two possibilities. One is that the button is going bad, or has a bad connection on one of its terminals. Or two the starter relay is going bad and causing heavier current in the button than intended.
Easy checks to make:
Using a piece of 10ga copper wire about a foot long, (with the tractor in Neutral and brakes on!!!) jump between the relay post connected to the battery, and the small terminal on the relay near it. It will spark a little, but if the relay is good the tractor engine will begin to turn over. (don't connect the 2 big terminals together with that small wire! it will get way hot and melt!)
If the tractor spins well the push button needs to be either replaced new switches can be poor quality, or the terminals on it need to be cleaned/tightened and shrink taped to seal out moisture.
If the tractor spins, but slowly, the cables might be incorrect size. They need to be 0gauge wires. These wires are about 3/8" of fine stranded copper with soldered on terminals. Typically prior owners use automotive cables of 4 gauge or so that are way too small. 6v systems use twice the amps of a 12v system and must have thick cables.
If the relay seems to not work well, or requires more than one attempt to engage the starter (series of clicks) replace it. Be sure to connect the new one with the same connection locations. Using 10-40 or 10-30 oil in it will also help in cool/cold weather. Jim
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
