Posted by Dave in Southern IL on December 04, 2014 at 10:40:55 from (50.122.58.67):
I have a 784 that I move round bales with. My bale mover (3 pt hitch bale forks) has a hydraulic cylinder on it to lift the forks higher than possible with the 3 pt hitch. My problem is that when I set the top link length so I can slide the forks under the bale, they are tilted down enough that the bales will slide off of the forks if on a grade. I would like to use a small cylinder for a top link so I can tilt the forks up after I raise the bale with the 3 pt. The problem is that I only have one remote. Can I put a "T" in the hydraulic lines for the cylinder on the bale mover so when I raise the bale up the "top link" cylinder will contract and tilt the forks up in the back to prevent the bale from sliding off? Then when I set the bale down to feed when I lower the forks with the bale mover cylinder will the "top link" cylinder extend so I can pull away from the bale without it dragging along? I know what I really need is another remote but they are kind of expensive. Any thoughts would be appreciated. Thanks, Dave
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
