Re: farmall 200 overcharging then not charging
Posted by Janicholson on December 05, 2014 at 13:26:41 from (199.17.55.171):
In Reply to: farmall 200 overcharging then not charging posted by Ramp;W on December 05, 2014 at 13:22:37:
Use a piece of copper wire (Solid is nice) to jump from the Bat terminal on the regulator to the GEN terminal. (not F ever) The tractor should not be running, but the battery should be hooked up and all wiring in place. This charges the Generator field iron cores with residual magnetism. to allow it to self start. If it still does nothing let us know. Jim
  Upload Photo  Select Gallery Photo  Attach Serial No List
