Re: Trying to Start Farmall H
Posted by Chris S. on December 09, 2014 at 16:21:27 from (174.54.6.73):
In Reply to: Trying to Start Farmall H posted by Cory Schmidt on December 09, 2014 at 16:11:37:
The tractor is running very slow at idle. And it will not even try to rev up. I actually thought maybe the throttle linkage was broke somewhere when I tried to throttle up and nothing happened. I checked out the linkage and everything is the way it should be. I did see the firing order stamped on the block. On the dristributer cap I see a number 1 printed on it. Should the first plug (looking left to right on the block) be in the number 1 plug on the cap? Because it's not. Its been forever sinse I've had to mess with friing order...Thanks!
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
