Re: Trying to Start Farmall H
Posted by Cory Schmidt on December 09, 2014 at 16:11:37 from (64.246.253.30):
In Reply to: Re: Trying to Start Farmall H posted by Chris S. on December 09, 2014 at 15:35:06:
Firing order is 1342 a wire might have been switched along the line when working on it. Don't recall what way the rotor turns might have to pull cap and see which way when cranked. Does it run fast when running at low throttle or slow(seams about right) If fast fuel might be to rich, if slower but can't speed up to lean someplace (high idle adjustment??) I can't help much with out being there to listen to/tweak it
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
