Posted by F150Mustang on December 09, 2014 at 19:09:25 from (67.41.67.183):
1, i know there are some difference between belly pumps on M's between the real early ones and later ones. My question, is a H and M belly pump the same?
2, On an vertical Delco Remy distributor there are two screw plugs on it. Presumably for lubrication, what would one use to lube these guys? 15/40, 80-90 or grease?
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
