Re: A couple Farmall Questions
Posted by khouse6 on December 09, 2014 at 19:27:31 from (173.242.241.45):
In Reply to: A couple Farmall Questions posted by F150Mustang on December 09, 2014 at 19:09:25:
i remove the screw plugs, thread in a zerk, grease fitting, and use the grease gun
the cost of a owners manual is cheap compared to letting something run dry of lubrication.
for instances, there is a screw in the fan hub on my C farmall, that i let run dry. did not know that it needed oil. sigh $80 to fix, plus my work
  Upload Photo  Select Gallery Photo  Attach Serial No List
