Re: IH 686 Fuel Filters
Posted by jimb2 on December 10, 2014 at 18:53:34 from (99.241.118.87):
In Reply to: IH 686 Fuel Filters posted by phil(va) on December 10, 2014 at 17:46:42:
Hi, should be a bleed screw on top of each filter housing.
Bleed filter closest to fuel tank first then bleed the next filter. Try to start engine after bleeding. If the engine will not start then loosen an injector line at the rear of the injector pump and try to start engine.
JimB
  Upload Photo  Select Gallery Photo  Attach Serial No List
