IH 686 Fuel Filters
Posted by phil(va) on December 10, 2014 at 17:46:42 from (76.1.142.89):
Replacing two fuel filters on 686 with 310 diesel engine. Thinking best to fill filters with fuel and then screw them on. Will this eliminate need to bleed system? If I have to bleed system, what is best way to do that? Filters have screw on bottom. Is that where you bleed air from the system if necessary?
  Upload Photo  Select Gallery Photo  Attach Serial No List
