Re: IH 686 Fuel Filters
Posted by mkirsch on December 11, 2014 at 05:02:10 from (72.45.143.81):
In Reply to: IH 686 Fuel Filters posted by phil(va) on December 10, 2014 at 17:46:42:
Yeah, if you try to fill the filters before you put them on you all but guaranteed to spill fuel all over the place. Much less mess if you install them dry and use the bleeders on the top of the filter bracket.
