300U clutch
Posted by jeffcat on December 11, 2014 at 18:35:24 from (69.244.99.202):
Ok here we go. The TA is stuck on my 300. The cover plate under the battery is the magic passage? I see there is a bunch of clutch stuff there so if you pull the handle back and use a small pinch bar to gently pry... will the clutch release? Rust from sitting too long not being run.
  Upload Photo  Select Gallery Photo  Attach Serial No List
