Posted by The tractor vet on December 12, 2014 at 07:24:59 from (104.179.81.68):
In Reply to: 300U clutch posted by jeffcat on December 11, 2014 at 18:35:24:
Here is a trick i have used , The cover plate bolts are little SHORT 1/4 inch bolts and do not give you any wiggle room so ONE at a time remove one bolt and get ones that are about a 1/4 x1 bolt and put that in where you removed the one also to aid in this deal there are three shipping bolt hole in the cover and if and again i said IF my old memory has not gone completely i think they ae a 5/16th by one with a flat washer this will pull the pressure plate back against the cover plate and remove the spring pressure . IF the sprag is good you will be able to only turn the T/A flywheel one way so just work around it and once you have removed all the short bolts and replace to the longer ones just to holt it in place then you can take a pry bar and pop the disc loose from the flywheel. Once it loose then just replace the short bolt back in and remove the shipping bolt readjust the linkage and work it . NOW due to age ware and tare most times the BOOK INSTRUCTIONS for adjusting the linkage will not get the job done and here it comes down to a FEEL adjustment and you will have to learn that one for your self.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
