Re: Farmall Cub Electrical
Posted by Janicholson on December 14, 2014 at 11:01:14 from (74.60.94.18):
In Reply to: Farmall Cub Electrical posted by RandyM on December 14, 2014 at 09:37:14:
There are possible problems in the light circuit, as well as the regulator, and possibly the amp meter itself. If the tests were done with the engine at 3/4 throttle or so, the system needs to be checked for a short in the light circuit, or non stock light bulbs or lamp systems. The voltage across the battery terminals really tells the story. An amp meter with age can become inaccurate due to thinning of the internal shunt. Voltage should be 6.3 or a fraction higher when nothing is on, not running. at 3/4 throttle the voltage should be 7.1 to 7.4 volts. Jim
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
