Farmall Cub Electrical
Posted by RandyM on December 14, 2014 at 09:37:14 from (67.240.153.143):
I've recently added a '54 Cub to keep the others in my barn
company. I have it running and thought of pushing some snow
with it just for fun. I intend to complete the rest of it in the
Spring as time allows.
I believe that everything was still original - wires, VR,
generator, etc. The generator was tested at the local auto
electric shop and is good. The battery is just over a year old
and is good.
When I start it, the D-O-C ameter pegs on full charge. If I set
the lights to dim, it shows a slight charge, and with lights on
bright it shows full discharge. The ignition switch was bad and
it was swapped for used one I had on the shelf. I've also
swapped out the 3-position light switch with one I had. This
did not change the charging indication. I've not yet put the
voltmeter on it to verify the charge in each condition.
I plan to rewire it and will likely install a new VR in the spring,
but for now, any thoughts on what might be causing the charge
to vary that much?
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
