Farmall H - gears, electrical, carburetor
Posted by Neal on January 08, 2001 at 20:31:41 from (205.188.199.27):
Just purchased a Farmall H. Runs good but has some continuous noise coming from the rearend (no thumps or clunks) Is this normal? I was planning on changing the gear oil. Should I flush with some sort of solvent beforehand? If so, what's the correct procedure?
Also, the tractor had been converted to 12v electrical system. I've been considering switching to an original 6v system. What are the pro's and con's? Does anyone make 6v reconversion kits?
Lastly, I just rebuit the carburetor. It runs good, however when I perform a cold start and choke the engine, I get some fuel coming out of the carburetor drain hole. This does not happen when the engine isn't choked. Is this normal?
Thanks,
Neal
Kingwood, Texas
Post A Followup
: Re: Farmall H - gears, electrical, carburetor
