Re: Farmall Cub Electrical
Posted by RTR on December 15, 2014 at 08:45:39 from (68.186.180.18):
In Reply to: Farmall Cub Electrical posted by Harry Klever on December 14, 2014 at 09:37:14:
Does it have a regulator on it or a CUT-OUT ? If it has a Cut-out then the light switch does control charging duties between high and low charge. An original light switch with 4 positions (Low-High-Dim-Bright) is needed in this case. Those old 6 volt systems work well when properly maintained and the correct parts used.
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
