Re: Impeller&shaft and dissasembly help MODEL H WATER PUMP
Posted by Buck Clayton on December 15, 2014 at 19:33:52 from (72.222.102.116):
In Reply to: Impeller&shaft and dissasembly help MODEL H WATER PUMP posted by djsamuraii on December 15, 2014 at 12:43:54:
MY 39 M had a hot water tap from top r. rear of head where temp. gauge is, using a T pipe.That line runs around back of motor to the Ensin unit near carb. and their is a line going to lower cast iron pipe to radiator. No water line fm. water pump.This tractor uses standard water pump. This should work on your H. Buck
  Upload Photo  Select Gallery Photo  Attach Serial No List
