Impeller&shaft and dissasembly help MODEL H WATER PUMP
Posted by djsamuraii on December 15, 2014 at 12:43:54 from (199.27.156.4):
I'm currently in the breakdown period of an 39 H. I took off the water pump and I'm rebuilding. "OR TRYING TO" I cant seem to find the shaft with impeller for the water pump online. I only found the impeller by itself. If any one could steer me in the correct direction I'd appreciate it. I also need help taking apart the pulley's from the center thrust shaft. I can't seem to break it free. I want to replace the bearings and seals. Any one with knowledge on this would be most appreciated.
