Re: F-30 questions
Posted by Brad on January 08, 2001 at 22:49:52 from (163.41.62.106):
In Reply to: F-30 questions posted by Mike Schwartz on January 08, 2001 at 19:11:37:
Hi Mike: I believe what you have in the 32 is what is called, duck bill steering. The 35 uses a worm gear steering.( Serial number 7032-and latter, which is, 1935 and latter) The duck bill uses front bolster #2279 Dax and the worm gear uses #3548 Dx. The two are not interchangable. The duckbill bolster uses the front axle shaft #26288 D, and the worm steer uses #27876 Dax and of course if the 35 is on rubber, it even takes another front axle shaft, with a bushing for added heighth. Thanks for making me do my home work tonight. I believe I'm correct but if I'm not, I'm sure someone with more knowledge on the f-30 will set me straight. Brad
Post A Followup
: Re: Re: F-30 questions
