Re: Impeller&shaft and dissasembly help MODEL H WATER PU
Posted by Nebraska Kirk on December 16, 2014 at 20:28:08 from (207.91.4.159):
In Reply to: Impeller&shaft and dissasembly help MODEL H WATER PUMP posted by djsamuraii on December 15, 2014 at 12:43:54:
You need to remove the bolts from the end of the pump and pull the piece off that the bolts are holding on. You can then more easily access the large nut which will have to be removed before the hub will pull off the shaft.
There is no pin on the generator pulley that needs to be removed. The pin you see on the large pulley is actually a screw that locks the movable half of the pulley in place. Do you see the threads behind the pulley? One half of it will screw in and out for loosening and tightening the belt that drives the pump.
This post was edited by Nebraska Kirk at 20:36:22 12/16/14.
