Maybe I confused you when I mentioned the pin in another post. Most times the reason it needs removed is for adjustable pulley replacement. See you have a hex nut that needs removed to slide hub off to replace bearings or seals. Some just have a nut with two flats like in picture. If your hub won't slide of after the hex nut removal, sometimes if bearings get bad enough to spin on the shaft it can be difficult to slide the hub off. Picture is a housing with the hub slide off. Also the pin location if you ever need to replace the adjustable pulley. Had this one apart to get the adjustable pulley for use on another one. Bearing and bearing spacer needs removed from hub before driving pin out. Impeller wasn't the best shape on this one also.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
