Re: Super h engine valve lift
Posted by D Slater on December 19, 2014 at 17:24:26 from (184.14.166.249):
In Reply to: Super h engine valve lift posted by David G on December 19, 2014 at 14:19:02:
If someone wanted to do the math they could figure out the approximate rocker arm ratio using the cam lobe lift and valve lift numbers I posted. Valve opening was measured with a dowel indicator contacting the top of spring retainers. Would think if I added the .019 valve to rocker clearance to valve lift it would tell me real real close what the rocker ratio was on the measured valve.
Camshaft number I posted is the same cam as part number 49900DCX in parts book. If its a later print parts book or IH on the line lookup the part number will show 49900DDX. IH didn't use the 49900DD until 350 production was already underway. Then used as a replacement cam for previous models. Difference between a DC and DD cam was the cam gear retaining threads, right on DC and left on DD.
This was a used cam so may have some wear. Think I remember seeing that the specs said .270 lift somewhere when new. Can't be sure on that though.
