Re: starter on Farmall C and electrical questions
Posted by Bob M on January 09, 2001 at 10:01:55 from (192.232.119.194):
In Reply to: starter on Farmall C and electrical questions posted by Jim H. on January 09, 2001 at 08:39:28:
Jim - If you get current flow thru the starter but it doesn't turn, it probably needs a rebuild. (I'm presuming the shaft is not frozen - i.e. it can be turned by hand...) The one thing you can do to the starter is check the brushes. It's possible one or more of them is worn out - will pass some current but not spin the armature. Brushes are cheap - about $5 for a set at the starter shop - and not too difficult to replace.
Regarding the generator system, you've got a 6 volt setup right now. The 12 volt battery is firing the coil, but the generator is not gonna charge the battery. My recommendation would be to return to the original 6 volt, positive ground configuration. You're going to need a 100% healty starter for this to work, and likely will the generator/cutout relay will require attention as well. (Chances are the starter was getting tired and generator failed long ago. The owner stuck the 12 volt battery in to keep the tractor in service, rather than fixing the problems...)
Good luck!
Post A Followup
: Re: Re: starter on Farmall C and electrical questions
Today's Featured Article - The Day Tractor Lovers Dream About - by Angus Crawford. The day started at five o'clock on the morning of Friday, the January 29, 1999. My father, my sister, my uncle, my cousin and myself all climbed into my uncle's Toyota van. It was six thirty in the morning and we had a long day ahead. We traveled for six and a half hours to our destination - a little country town with a population of no more then one hundred and fifty people (57 of them being children under the age of thirteen). We arrived hoping to meet up with a man we knew had over one ... [Read Article]
