Posted by picassomcp on December 19, 2014 at 18:46:35 from (50.124.216.146):
I just bought myself a 1486, decent tractor, mostly original. I had it out for a ride yesterday and went to downshift the torque. I shifted it quickly liked I've always been told to do. for an instant there was nothing, then a clickety clunk kinda noise (sounded like a 2 speed rear end engaging) then the tractor took off in low torque as normal. I tried it again about 5 minutes later, same thing. The shift happens, its just a bit slow and makes that noise. Once in low t/a, I pressed to brakes to see if it would slip, it did not slip a bit. It was about 15 degrees out that day, so a bit cold, but the tractor had been running for about 10 minutes before I moved it at all.
I'm hoping that the T/A is not checking out. Is there an adjustment that may help get a better downshift? Shifting up seems normal. The hydraulic fluid looks like it has been changed recently.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
