Re: 1486 T/A shifts goofy
Posted by Jon Hagen on December 20, 2014 at 17:53:53 from (69.26.17.105):
In Reply to: 1486 T/A shifts goofy posted by picassomcp on December 19, 2014 at 18:46:35:
Might be a worn sprag clutch, but there is also a chance the tractor has been fitted with a late model "mechanical diode" TA that uses a mechanical diode in place of the sprag clutch. That may chatter a bit before the speeds match up and the MD locks.
Same as the others, do not downshift the TA to slow down if in the highest gears, very damaging to the TA.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
