Re: removing / installing dry sleeves
Posted by Cory Schmidt on December 20, 2014 at 14:38:56 from (64.246.253.39):
In Reply to: removing / installing dry sleeves posted by heck914 on December 20, 2014 at 14:17:18:
From your rough description of your puller it should work. That is what I use here. They will be hard to pull. To install them freeze the sleeves. Cooling things causes them to contract (smaller). Then reverse your puller(pull them in from top, blocking puller on bottom of block) to press them back in. Be careful you don't press them in to far or fast to keep from breaking the lip off of the sleeve.
  Upload Photo  Select Gallery Photo  Attach Serial No List
