Posted by heck914 on December 20, 2014 at 14:17:18 from (32.212.65.10):
just got an engine kit for my Uncle's 39 Farmall H. Any tips or advice on removing / installing dry cylinder sleeves? I fabricated a puller with a steel disk , steel, and some threaded rod. Will this work or do I need to press them out ?? heat the block ? On installation , do I need to freeze the sleeves ?
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
