Re: removing / installing dry sleeves
Posted by jal-SD on December 20, 2014 at 15:53:57 from (208.53.222.164):
In Reply to: removing / installing dry sleeves posted by heck914 on December 20, 2014 at 14:17:18:
After you get them out and clean the inside of the block as described below, don't forget to clean the groove at the top of the block bore that the new sleeve fits into. A little dirt in that groove will break the top of the sleeve in a heart-beat! (Don't ask how I found out about that little bit of dirt will break a sleeve.) A little light machine oil on wiped the inside of the block bore or the sleeve itself makes things go in a lot easier. I used a rag that had been sprayed with "Rem-Oil" (gun oil) to wipe the bore the last time I put in a set of sleeves and it worked great. Just be sure you don't over do the oil, just enough to make it a little "slick". (My $0.02 worth. jal-SD)
  Upload Photo  Select Gallery Photo  Attach Serial No List
