Posted by John T on December 22, 2014 at 06:37:09 from (216.249.72.121):
In Reply to: voltage regulater help posted by flopguns on December 21, 2014 at 13:54:52:
For one thing, a Voltage Regulator should be compatible with whatever ground you have, be it Pos ground or Neg ground. Another thing is way back when a Voltage Regulator was more closely matched to a certain generator while nowadays it (availability) may be more of a one size fits all approach which sure will still "work" but not near as well as if the genny and VR are more closely matched as I suspect was the case in the fifties etc. A VR plus the Genny BOTH need a good ground to work properly.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
