voltage regulater help
Posted by flopguns on December 21, 2014 at 13:54:52 from (173.187.61.94):
Hello, need some help with my Super-A with 6v pos ground. Has been a headake goes through about 1 regulater ever year last one worked good for about a year then it got so you would have to tap on it to get it to work . so today put a new one on it fired it up . charging good let it run about ten minutes looked at the amp guage was discharging taped on the regulater started charging again afew minutes later it was discharging again. help in north carolina
  Upload Photo  Select Gallery Photo  Attach Serial No List
