Re: voltage regulater help
Posted by redforlife on December 22, 2014 at 11:27:51 from (68.234.121.124):
In Reply to: voltage regulater help posted by flopguns on December 21, 2014 at 13:54:52:
Everything that needs grounded , needs good tight clean connections. If you have a positive 6v system, then you need a 6v positive ground regulator. You can get others such as negative ground regulators but its not what you need and you will likely have problems if trying to use one of them. Generators commonly need to be polarized after some of the electrical system has been apart and back together. If it needs polarized, it will cause a dis-charge rather than a charge. Other components need to be good for the system to work. Good battery, generator, and so on. One more thing, it doesn't take much at all to mess up a regulator. Like allowing the generator to dis-charge from not being polarized will just fry the dang thing in pretty short order.
  Upload Photo  Select Gallery Photo  Attach Serial No List
