Farmall A Belt Drive Question
Posted by orion1 on December 22, 2014 at 18:03:08 from (67.240.204.23):
I want to take the PTO/belt drive off of my Farmall A tractor and put on a flat cover plate. My question is do I need to do anything besides take the bolts out of the rear and pull it out and bolt the plate on? Are there any internals that need to be disconnected or parts added? Thanks for any help!
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
