Re: Farmall A Belt Drive Question
Posted by Jim Becker on December 22, 2014 at 18:48:16 from (173.84.240.213):
In Reply to: Farmall A Belt Drive Question posted by orion1 on December 22, 2014 at 18:03:08:
If you are talking about the entire PTO attachment, it is about that simple. Removing the belt pulley attachment and keeping the PTO is not.
Either drain the transmission oil out first or park it pointing down a steep hill. It will drain out the opening for the PTO.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
