Re: engine miss- low compression on my 400
Posted by Bob on December 25, 2014 at 10:29:17 from (64.255.159.192):
In Reply to: engine miss- low compression on my 400 posted by SDE on December 25, 2014 at 09:13:28:
Check that the pushrods are in place and that the valves are correctly set.
Then, do a leakdown test to verify it's leaking past the rings.
If it is, you will simply have to tear into it to see what broke, 'cuz the ones of us out here on the 'net are no better at x-ray vision than you are?
(STILL trying to figure out why you took the piston and sleeve out if it was obvious the head was cracked???)
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
